I have a 2006 Road King that has a stumble between 1800 to 2200 rpm's. If I run it steady it is really evident. The biggest issue is when I turn around and when it passes through the range it stumbles and tries to fall over. It has caused me to lay it over a couple of times. Does not store an error code and dealer replaced the engine temp sensor. Any help would be appreciated.
