I have a 2006 Sportster 1200c that after running about 10 minutes oil will pour out of the Air Cleaner. I shut it off and checked the oil level and it was low. I let it set for a few about 5 minutes. and started it back up and I could see oil returning into the oil Tank. I shut it off and you could see it draining back into the engine. I took the Oil Filter off and checked the Check Ball in the Filter housing and it wasn't stuck but was shocked to see it is Plastic. Called the local Dealer and was told it is Obsolete. Oil PSI is normal and with it returning back into the Tank the Return Gears should be ok. I did notice that when I took the Dipstick off it seemed not to do it so bad. Any advice would be Appreciated.
