2005 flstni fuel gauge removal
Discussion in 'Softail Models' started by twoup, Mar 5, 2010.
  1. twoup
    twoup Active Member
    205
    How do I get the wiring off the gauge? Have it removed from tank but can't get any further. thanks. vince
  2. Chopper
    Chopper Senior Member
    1,632
    19
    Not sure I understand the question? If you look below the left side of the tank where the wires come out, just follow the wires to the plug and unplug conector #4, then release the pins from the conector and pull the wires up through the top of tank.
    [​IMG]
  3. twoup
    twoup Active Member
    205
    thanx chopper.
    ride safe
  4. NEWHD74FAN
    8,191
    98
    19
    Just curious, is the mate connector above a phantom located in the "tunnel" or in the isolated chamber in the tank?
  5. Chopper
    1,632
    19
    It is below the fuel tank, usually stuck up between the tank & frame.
  6. NEWHD74FAN
    8,191
    98
    19
    Thanks Chopper, I am curious if anyone has retrofited a carb tank with a digital fuel guage like the one for 2007 up EFI models? I am thinking of adding one to my Sporty if it is not too crazy an idea. Sorry, I hijacked this thread a bit, as the kit is for newer EFI equipped Sportsters...but may be an option if the mastercylinder/covers are compatible (DOT5 Silicone fluid in my 2004 Sportster.
    [​IMG]
    Genuine Motor Accessories | Harley-Davidson USA
