2003 Electra Glide Diagnostic Code?
Discussion in 'Touring Models' started by RICH SMITH, Jun 19, 2012.
  1. RICH SMITH
    RICH SMITH Member
    8
    hello everybody i'm new here, i have a 2003 electraglide and the check engine light came on , when that happened the idle dropped , also the speedo quit working and the turn signals dont shut off on there own . i checked the codes and its giving me a d025eb and i cant find that code anywhere too say what it is, i can get it to clear but after you run it it comes back . also check engine light not on any more. can anybody help? thanks
  2. R_W_B
    R_W_B Senior Member
    2,425
    23
    re: 2003 Electra Glide Diagnostic Code?
    I'm not real sure how to interpret the codes with the 2003's and before. Maybe someone with more experience in that year bike will come along.
    However I found this posted long ago by a certian helpful individual with a currently frozen account.
    Diagnostic codes for 2003 Road King?
    1. Remove right side saddlebag and side cover if so equipped. Remove protective plug from data link connector.
    2. To activate the diagnostic feature, proceed as follows:
    a. Create diagnostic test wire or use a female spade clip.
    b. Install diagnostic test wire across Terminals 1 and 2 on the data link connector.
    c. Turn Ignition/Light Key Switch to IGNITION and wait approximately 10 seconds (4 seconds lamp ON, 6 seconds lamp OFF) for check engine lamp to start flashing.
    3. All trouble codes are sent out as a series of flashes. To retrieve the first digit of the trouble code simply observe the number of times the lamp flashes.
    a. The lamp will then flash one or more times to indicate the first digit of the trouble code.
    b. The length of time the lamp is illuminated and the length of time in which it is off are each about 0.5 second in duration.
    4. The second digit follows:
    a. Following the transmission of the first digit, there is a 1.2 second pause in which the lamp is off.
    b. The lamp will then flash one or more times to indicate the second digit of the trouble code. Count the number of times the lamp flashes to retrieve the second digit.
    5. If more than one trouble code is sent:
    a. Following transmission of the second digit of the first code, there is a 3 second pause in which the lamp is off.
    b. Once all codes have been sent, the data string is repeated. When you have recorded the same trouble code twice, it is an indication that the transmission has been restarted and that all trouble codes have been retrieved.
    IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A “trip” consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diognostics manual you're peeing into the wind.
    1 Current 53 ECM flash error
    2 Historic 53 ECM flash error
    3 Current 54 ECM EEPROM error
    4 Historic 54 ECM EEPROM error
    5 Current 63 ECM serial data low
    6 Current 63 ECM serial data open/high
    7 Current 63 TSSM serial data low
    8 Current 63 TSSM serial data open/high
    9 Current 61 Loss of TSM/TSSM serial data
    10 Current 14 Loss of all ECM serial data (state of health)
    10 24 Loss of vehicle speed
    10 33 Loss of vehicle inhibit motion
    10 43 Loss of power train security status
    11 Current 33 System relay contacts open
    12 Current 33 System relay coil high/shorted
    13 Current 33 System relay coil open/low
    14 Current 33 System relay contacts closed
    15 Current 99 Incorrect password
    16 Current 99 Missing password
    17 Current 41 CKP sensor intermittent
    18 Current 41 CKP sensor synch error
    19 Current 11 TP sensor open/low
    20 Current 11 TP sensor high
    21 Current 12 MAP sensor open/low
    22 Current 12 MAP sensor high
    23 Current 14 ET sensor voltage low
    24 Current 14 ET sensor open/high
    25 Current 15 IAT sensor voltage low
    26 Current 15 IAT sensor open/high
    27 Current 24 Front ignition coil open/low
    28 Current 25 Rear ignition coil open/low
    29 Current 24 Front ignition coil high/shorted
    30 Current 25 Rear ignition coil high/shorted
    31 Current 24 Front cylinder combustion intermittent
    32 Current 25 Rear cylinder combustion intermittent
    33 Current 23 Front injector open/low
    34 Current 32 Rear injector open/low
    35 Current 23 Front injector high
    36 Current 32 Rear injector high
    37 Current 16 Battery voltage low
    38 Current 16 Battery voltage high
    39 Current 43 VSS sensor low
    40 Current 43 VSS sensor high
    41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
    42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
    43 Current 35 Tachometer low
    44 Current 35 Tachometer high
    45 Current 25 Rear cylinder no combustion
    46 Current 24 Front cylinder no combustion
    47 Current 34 Loss of idle speed control IDLE AIR CONTROL
    48 Current 35 Accelerometer fault
    49 Current 34 Starter output high
    50 Current 25 Ignition enable output high
    51 Current 21 Left turn output fault
    52 Current 22 Right turn output fault
    53 Current 11 Battery voltage high
    54 Current 31 Alarm output low
    55 Current 32 Alarm output high
    56 Current 41 Ignition switch open/low
    57 Historic 63 ECM serial data low
    58 Historic 63 ECM serial data open/high
    59 Historic 63 TSSM serial data low
    60 Historic 63 TSSM serial data open/high
    61 Historic 61 Loss of TSM/TSSM serial data
    62 Historic 14 Loss of all ECM serial data (state of health)
    63 Historic 33 System relay contacts open
    64 Historic 33 System relay coil high/shorted
    65 Historic 33 System relay coil open/low
    66 Historic 33 System relay contacts closed
    67 Historic 99 Incorrect password
    68 Historic 99 Missing password
    69 Historic 41 CKP sensor intermittent
    70 Historic 41 CKP sensor synch error
    71 Historic 11 TP sensor open/low
    72 Historic 11 TP sensor high
    73 Historic 12 MAP sensor open/low
    74 Historic 12 MAP sensor high
    75 Historic 14 ET sensor voltage low
    76 Historic 14 ET sensor open/high
    77 Historic 15 IAT sensor voltage low
    78 Historic 15 IAT sensor open/high
    79 Historic 24 Front ignition coil open/low
    80 Historic 25 Rear ignition coil open/low
    81 Historic 24 Front ignition coil high/shorted
    82 Historic 25 Rear ignition coil high/shorted
    83 Historic 24 Front cylinder combustion intermittent
    84 Historic 25 Rear cylinder combustion intermittent
    85 Historic 23 Front injector open/low
    86 Historic 32 Rear injector open/low
    87 Historic 23 Front injector high
    88 Historic 32 Rear injector high
    89 Historic 16 Battery voltage low
    90 Historic 16 Battery voltage high
    91 Historic 43 VSS sensor low
    92 Historic 43 VSS sensor high
    93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
    94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
    95 Historic 35 Tachometer low
    96 Historic 35 Tachometer high
    97 Historic 25 Rear cylinder no combustion
    98 Historic 24 Front cylinder no combustion
    99 Historic 34 Loss of idle speed control
    100 Historic 35 Accelerometer fault
    101 Historic 34 Starter output high
    102 Historic 25 Ignition enable output high
    103 Historic 21 Left turn output fault
    104 Historic 22 Right turn output fault
    105 Historic 11 Battery voltage high
    106 Historic 31 Alarm output low
    107 Historic 32 Alarm output high
    108 Historic 41 Ignition switch open/low
  3. RICH SMITH
    RICH SMITH Member
    8
    thanks RWB I'M NOT REAL SURE ABOUT THE CODES EITHER BUT I WISH I COULD FIGURE THIS THING OUT SOON WE HAVE BEAUTIFULL WEATHER HERE AND I WANT TOO RIDE
  4. Jeff Klarich
    4,843
    103
    496
    Welcome from Minnesota.:wbs
  5. RICH SMITH
    RICH SMITH Member
    8
    thanks jsklari
  6. Jack Klarich
    Welcome to The Forum, I cant find any info on that trouble code
  7. Jack Klarich
    Invoking engine diagnostics on a < 2003 Harley =
    To activate the diagnostic feature of the Check Engine Lamp, proceed as follows:
    1)Turn the Ignition/Light Key Switch to IGNITION for three seconds (one second pause after the fuel pump stops running), and then turn switch back to the OFF (FLHTC/U-I, FLTR-I) or LOCK (FLHR/C-I) position for three seconds.
    2)Repeat the instructions under step 1. above
    3)Turn the Ignition/Light Key Switch to IGNITION and wait approximately eight seconds for the Check Engine Lamp to start flashing.
    4)All trouble codes are sent out as a series of flashes. To retrieve the first digit of the trouble code simply observe the number of times the lamp flashes. The lamp will then flash one or more times to indicate the first digit of the trouble code. The length of time the lamp is illuminated and the length of time in which it is off are each about 0.5 second in duration. The second digit follows: following the transmission of the first digit, there is a 1.2 second pause in which the lamp is off. The lamp will then flash one or more times to indicate the second digit of the trouble code. Count the number of times the lamp flashes to retrieve the second digit.
    5)If more than one trouble code is sent: following transmission of the second digit of the first code, there is a 3 second pause in which the lamp is off. Once all codes have been sent, the data string is repeated.
    EFI Diagnostic Trouble Codes (DTC) and Fault Conditions
    There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
    10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
    Is this the Procedure you used?
  8. RICH SMITH
    RICH SMITH Member
    8
    thanks jack i'll try that tonight and see what i get :)
  9. tourbox
    tourbox Senior Member
    1,902
    173
    There are speedometer codes that are D01 thru D10. If it is a 5 digits then it is a Speedometer Pulse per Unit. That was a list I got from a HD mech. buddy.I don't recall the years but were the earlier ones. The 2 letters at the end of your code throws me off though.
    tourbox
  10. RICH SMITH
    RICH SMITH Member
    8
    thanks tourbox, that code comes up on D02, it is d025eb i've looked in a manual in yhe list of codes and cant find it, yesterday i called the local harley shop and told them the code and what the bike was doing and they said that it sounds electrical and told me to check battery terminals and grounds and everything seems ok to me. i'm probably going to have to take it in and have them put the scan tool on it to find out what is wrong . i just know that this is driveing me crazy.
