03Twinkie
I put on some Lyndall Gold brake pads front/rear. Other than that all stock Harley. The rear inboard pad is dragging a little, which keeps the brake rotor warm. The pins showed no sign of wear other than superficial. The pistons were cleaned and retracted into the bores. Even with the inboard pistons fully retracted, the inboard pad was tight during assembly. The outboard pad was loose. I can see through some windows on the top of the stock caliper that the inboard pad is moving toward the rotor and then retracting, but it is still dragging. It seems as though the 4 piston non-floating stock caliper isn't properly aligned to the rotor, but there doesn't seem to be a way to align the caliper or rotor, for example with shims, since the caliper and bracket are one unit mounted to the rear axle and the rotor is hard mounted to the rear wheel. This may have been an issue in the past, but I can't recall if I've ever tested it. Maybe the stock Harley pads are thinner than the Lyndalls.
