For starters new to your site would like to say HI to all. :60:My 2003 Deuce has the check eng light showing a historic code. After I select run and Ing. the eng light comes on, the fuel system pump runs up and the light goes out. Then a few seconds later the check eng light comes back on for 8-10 seconds and then goes back off. Bike runs great. A little history just had the chain cams replaced with gear cams , has a DFO installed and I beleive it is a Stage I breather, and magnum plug wires. The day before I noticed the check eng light, the eng did back fire, and when I went to put gas in after the back fire I noticed the eng light cam on, and a code went buy the odomiter but it went away. The next day I noticed the eng light coming on every time I started the eng with a historic indication. Put a Scanalyzer on bike and the eng light flashed the historic indication, and then went out, but no code could be read by Scanalyzer. From the info I have found on your site is this not a problem, and I just have to wait the 50 cycles to see what happen. But if the problem is causing the historic indication each time how can I find out what might be the problem, short of replacing items.
