free website stats program 2002 Electra Glide Un-Lower? | Harley Davidson Forums
Foxman
Hey there,
Just wanted to see if this has been done and what may be required. I bought this bike with a "2 inch lowering kit" on the rear and am tired of the tire scraping my rear fender when I hit dips in the road, so I'd like to put the rear back at stock height. I think this is the shock re-location mount on the rear shock style of lowering kit. Do I need to replace the hardware with stock hardware, or jusst remove the lowering mount and re-use the shock bolt in stock location? Thanks for any suggestions.
Hey there,
Remove the lowering block and re install shock to original mount hole with new bolt and lock washer use a torque wrench:s
You'll be glad you did too. The ride almost has to improve. Not even taking handling into account. Is the front lowered? If so you may consider un-lowering it too.
