2001 road king FLHRI
Discussion in 'Touring Models' started by madd4225, Aug 16, 2009.
  1. madd4225
    madd4225 Member
    10
    hi have the road king fuel injected with hooker slip on exghust. my buddy when riding behinde me noticed that everyonce in a while when i down shift that it blows a flame out the right side of the exghust and pops and crackles. i told him i thought the exghust was supose to pop and crakle i wasnt sure about the flame. on that same side the is a lot of carbon build up at the end of the exghust.
    i did just get this bike and do not no if its just stock motor or anything special any help or in for i thank i advance thanks
    Sounds like it's running a bit rich. Do you know anything about the ECM if it has a download or if the bike has a fueler on it?
  3. sanec1
    sanec1 Active Member
    159
    The left pipe is a resonance chamber more than an actual exhaust from what I've read here. I have a RK too and a friend noticed some flame action from the right pipe the other day. Same with the carbon being more noticeable on the one side. Pop off the seat and have a look for a Fuel injection box. Or it could be located on one of the side panels that pop off
  4. jerrybombard
    jerrybombard Active Member
    115
    COOL !!!!! :D
    Can you make it flame from both sides???
    When you figure that out, let us know.
    That will keep the traffic around here from being so close. And look GREAT at night !!!
  5. madd4225
    madd4225 Member
    10
    glider not sure is their a way i can check. did get the service manual is their a step by step in their.
  6. TQuentin1
    4,737
    142
    There are a number of fuelers that may have been added if you have an EFI bike. Is yours EFI or carb? Will make a difference what to look for.
  7. glider
    Like TQ said, give more info and we can help you out.
  8. madd4225
    madd4225 Member
    10
    yes it is fuel injected
  9. jody7734
    jody7734 Active Member
    221
    There are a few companies that make flame kits, one of them is hot licks exhaust. It does require welding a bung into the exhaust and richening up your mixture.
