What gives...speedo has failed...is this a voltage regulator issue.or wiring....any help would be appreciated... thanks
If your blinkers have stopped self canceling too, check here. Use a good GEAR OIL like Mobil 1 75-90 or 75-140 or even redline shockproof heavy in the transmission, bet you have syn 3 in there now. http://www.hdtimeline.com/electrica...763-speed_sensor_pickup_problem_symptoms.html
my sppedo,odometer and turn signals cut off and then back on sporadically. The bike runs fine besides those problems. I have a 03 fatboy. I'll get back to you if I hear anything Sean
Check your other post http://www.hdtimeline.com/softail_models/2131-electrical_problems_on_my_03_fatboy.html
