free website stats program 2000 Dyna Solid Turn Signal | Harley Davidson Forums
So got my Dyna back up and running and she’s running great!
The only issue I have is this:
Previous owner put LEDs in front and rear turn signals. Left side is perfect. When I put on my right side turn signal, it’s just solid on front and rear, and on the indicator panel.
when I bought the bike it came with a Badlands load equalizer that was not installed. Do I need it, and how/where do I install it?
For reference this is not the plug and play badlands, it is the 4 wire (purple, brown, red, and ground)
If I remember correctly from posts in the past an equalizer is needed, not sure of how to connect but someone will chime in.
Jeff is correct in what he said.
I googled it and came up with 2 videos.
Have a look at them and see if it helps you.
https://www.google.com.au/url?sa=t&...=00JngY3xHxA&usg=AOvVaw1XBXdUDqxNJXUZ-n0rBoPX
[URL]https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwji1qH18sf2AhVazzgGHRaCAHUQwqsBegQIBBAB&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DxSh31-g2rfg&usg=AOvVaw07Wc7-Zbw7LiIOB8JGubEw
[/URL]
