200 rear question
Discussion in 'Touring Models' started by Turk55, Aug 11, 2011.
  1. Turk55
    Turk55 Active Member
    138
    Got an 09 SG with 200 rear tire on it, question I have is it normal to the tire to be offset to one side more than other? Looking from the rear, the tire sets to the left to the point that it just rubs the drive belt. someone said that the 200 is offset but this doesnt seem right.:nosad
  2. Redfish-Joe
    Redfish-Joe Senior Member
    2,307
    10
    Lets see some pics.
  3. glider
    50
    If the tire/wheel has been off the bike, there's a possibility that the spacers are incorrectly installed OR the wheel is not lined up right.
  4. Turk55
    138
    So I find out that the spacers are on correctly, problem is that eventhough Harley offers a 200 kit to put on the SG they did not make a change to the spacers:small3d015: so here is question, they do offer the Fat Boy with a 200 on it, any reason I can't use a set of these to center my wheel?
  5. eleft36
    eleft36 Junior Member
    441
    The sprockets won't line up.
    The engine will have to be offset to line up the front sprocket to the rear sprocket.
    There must be a difference in the rear fork or main frame.
    Al
  6. Turk55
    138
    So I guess the only way to fix the problem is to do some measuring and have a machine shop make some up.
