1999 FXDWG Mainshaft Inner Bearing
Discussion in 'Dyna Models' started by northernrider, Jan 7, 2011.
  1. northernrider
    northernrider Member
    43
    My primary was leaking really bad on road trip replaced the seal in a parking lot in Montreal main shaft inner bearing was worn it had 150000 miles on it.
    The biggest issue I could not use the puller to remove it was installed or had moved hard up against the final drive. Had to cut it off.
    I have heard on high horse power engines the main shaft inner bearing can move but my bike is stock.
    Anybody else had the same problem ?:CANADA
  2. TQuentin1
    4,737
    142
    No, but Baker makes a bearing that does not need the race on the shaft. See here:
    BAKER Drivetrain | Premium Drivetrain Upgrades | Pieces Parts
  3. fin_676
    5,788
    153
    287
    Re: 1999 FXDWG Mineshaft Inner Bearing
    It has perhaps been removed in the past and reinstalled incorrectly
