1992 whining transmission 3rd & 4th gear
Discussion in 'Transmission' started by bikerguy133, Jul 19, 2015.
  1. bikerguy133
    bikerguy133 Member
    5
    just bought a 92 sporty with 6000 original miles. the thing sounds good engine wise, but when i'm riding and shifting into 3rd & 4th gear i get this whining noise. shifts ok but the noise is driving me nuts. checked the primary chain, all looks good. makes the noise accelerating and decelarating mostly in 3rd n 4th. i know these older harleys are natorious for strange noises, but is this normal? was looking to flip this bike , but dont want to sell it with problems! comments appreciated!
  2. Jack Klarich
    Have you checked your fluid level and alignment of rear chain?
  3. bikerguy133
    bikerguy133 Member
    5
    fluid level ok, going to go out and check the rear chain. good suggestion , but if it were the chain, wouldnt it make the noise all the time?
  4. Jeff Klarich
    4,805
    103
    486
    Could be just more noticeable in those 2 gears. How much play in the primary chain did you have?
  5. fin_676
    5,779
    153
    285
    It could be that the pitch of the whine changes with different speeds and the audible pitch under some conditions can be out of the range of human hearing
    [​IMG]
  6. bikerguy133
    bikerguy133 Member
    5
    half " play in the primary. just pulled the drain plug, not a spec of shavings.put vtwin 20/50 mobile 1 tranny fluid in it, sounds a little better.
  7. Jeff Klarich
    4,805
    103
    486
    That may be a little tight and could be causing the whining sound.
  8. fin_676
    5,779
    153
    285
    Tight primary chain will whine once bike gets hot and the sprocket and clutch drum expand with heat always set primary chain tension when bike is cold and at the tightest point on the chain
    [​IMG]
