1992 Sporster Oil Leak at Base
Discussion in 'Sportster Models' started by stm1258, Oct 11, 2009.
  1. stm1258
    stm1258 New Member
    Hi All,
    I have a 92 Sportster. The head gaskets were replaced in the spring and now I am losing oil at the base. Plus my compression is down since a piece of the gasket is gone. How hard is it to replace these yourself? Anyone have a good manual they can recommend?
    Thanks
    Can't beat the HD factory manual. The heads have to come off to do the gaskets. If you aren't too mechanically inclined I would have someone help or do the job for you.
  3. fin_676
    5,779
    153
    285
    The thing i found worst on this one was scraping the old base gasket off
    both the clymer and hd service manuals cover this procedure equally well
    the task can be done with the engine in the frame there is a bit more room on the front cylinder
    do a bit of research on replacement base gaskets as there are better ones than the stock
  4. hippie13
    hippie13 Active Member
    116
    my 91 use to leak at the lower pushrod tube oring ( lookd like a base gasket leak ) the stock ones never seem to fit right .
    its a pretty strait forward engine to work on though , afew special tools and a good book should get you through it if you have some mechanical knowledge
  5. Jack Klarich
    Like Glider said and if you do tackle the job yourself be careful scraping the old gaskets try not to gouge the deck of the motor I like Permatex spray gasket remover a couple of apps and let it soak good luck, Jack
