1992 fxle Ignition Cover.
Discussion in 'Engine, Fuel and Exhaust' started by jackotom, Mar 4, 2012.
  1. jackotom
    jackotom Member
    5
    Hi, does anyone know how to remove the engine cover what the ignition is in?
    iv'e removed the allen bolts but it wont move,i want to have it re-chromed.
    thanks dave.
  2. Jack Klarich
    Did you remove the rivets in the center cover and remove the ignition first? The Cover will come of next, careful to not lose any spacers that will fall out, and replace the cam bushing and recheck the breather spacer, might as well check the breather as long as you are in there, some of the plastic ones were bad
  3. Breeze3at
    Breeze3at Well-Known Member
    4,922
    224
  4. jackotom
    jackotom Member
    5
    Hi, thanks for the reply, if i remove the electronic ignition will it have to be set up again when i install it? this is my first harley and at the moment and have never removed a electronic ignition before and i don't have a manual.
    the ignition is a (Crane Programmable Module Model Hi 4)
    thanks dave.
  5. jackotom
    jackotom Member
    5
    Hi, it looks like the evo evolution 93 one.
    thanks dave.
  6. Jack Klarich
    Yep, http://www.nightrider.com/biketech/download/crane/install_hi4_race2.pdf This should help you to understand the system:s
  7. johnflorida
    johnflorida Member
    25
    Just mark the plate and case so you can line it back up
