1982 FXRS w/Barnett Clutch
Discussion in 'Transmission' started by Panhead Jeff, Jun 19, 2012.
  1. Panhead Jeff
    Panhead Jeff Member
    5
    The clutch has less than 15k and I have adjusted the cable. Even tighten the spring tensioning nuts evenly. Yet every once in awhile while releasing the clutch it just grabs. I'm talking only letting out maybe 1.5 -2 inches which causes the bike to surge forward. What is causing this? I haven't checked the clutch hub to see if the fingers are worn and that maybe why the clutch is hanging up. Thanks for any help.
  2. Jack Klarich
  3. Panhead Jeff
    Panhead Jeff Member
    5
    It's a 5 speed rubber mount FXRS.
  4. SledDog
    SledDog Senior Member Staff Member Moderator
    2,121
    68
    88
    Your basket may be wobbling, check the alignment of the basket and the front sprocket. Also check the studs on the basket to make sure have do not have a groove in them. Did you change the steels when you did the clutches? If not. you may have one that's warped. Use a straight edge to verify they are ok.
