carellic
My new bagger is on the way and, as I stated in my intro post, dealer is offering very good conditions if I upgrade before delivery. Purpose is to enhance low rev torque without losing power in the high end. And sound, of course!
It would be great help to know your opinions about what I'd like to install:
- SE stage I 110" kit (with SE-255 cams)
- Ventilator air cleaner
- V&H Monster Round slipons
- Floating brake rotors
Main doubts are for the 110 kit, very expensive (much more here than in the US, just like HD bikes. And all parts and accessories as well!) and, if I got it right from what I found in the self help section, heavy work must be done to cases/basement, and possible problems with crank and/or bearings (and oil leakage from rear cylinder but that was 2008 and before I believe).
Would I get anything comparable changing stock cams with SE-255 on the 103" stock engine (same air cleaner and slipons)?
A guy at Bike Hospital (a garage nearby) suggested that leaving engine alone and installing a Thunder Max ECM would be much more effective than cam upgrade and remapping. Should I listen to him?
Sorry for the length but I'm a little confused by information overload :newsmile082:
Thank you in advance!
Claudio
Claudio
