103 Head Question
Discussion in 'Engine, Fuel and Exhaust' started by Rod Stewart, Oct 9, 2012.
  1. Rod Stewart
    Rod Stewart Active Member
    299
    Anyone know the chamber volume of the stock HD 103 heads?
    Is it the same 85 cc as for all previous stock twin cam engines?
    Thanks,
    Rod
  2. Bodeen
    4,647
    73
    222
    I read somewhere that they are 85cc's but cant be sure.
  3. dolt
    dolt Senior Member
    2,185
    103
    341
    Bathtub chamber volume typically runs between 85cc-86cc but I have seen them measure as high as 89cc.
  4. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    I just had a set of 08 heads re-newed and blueprinted by "Deweys Heads" of Wa.
    Like dolt said above, one of mine was very far apart of the other.. so accurate measurement is needed to get them equal... And a good head man to check... Thanks Don Doorfman...
    I Know of No difference in the stock heads, being either 88", 95", 96" or the 103". Same..
    85cc
    Looking at Big Boyz caculator, they call out for 85cc as their stock starting numbers.
  5. FishHunter
    FishHunter Active Member
    134
    They average between 85-87 cc's.
    A good cfm, for a 103-107 ci engine is right around 160 cfm, @ 10"/.600" lift.:)
  6. Rod Stewart
    299
    Thanks to all for the info.
    I am slowly getting my head around all the head variations.
    The best,
    Rod
  7. FishHunter
    134
    Rod,
    Do you know of an outfit, in Edmonton, by the name of Fabmasters Ltd.?
  8. Rod Stewart
    299
    FishHunter;
    I am not familiar with Fabmasters. What do they do?
    Harley made Screaming Eagle 103 heads for a while.
    Anyone know the chamber volume and valve sizes for these?
    Thanks,
    Rod
  9. dolt
    dolt Senior Member
    2,185
    103
    341
    Need part numbers.
  10. FishHunter
    134
    Yes, part #'s for the particular cylinder head would aid greatly to arrive at a conclusive answer.:)
