KIT CUSTOM
Bike wouldn't start. Starter wouldn't turn over. Took apart the starter button,checked all the wiring,tested the relays.No choice now but to pull the starter and soliniod. Found them both saturated with oil. Cleaned everything up, bike starts like new. Now to the question. How did they get oil soaked ? As far as I can tell the only opening is through the jack shaft but how could enough oil get through there to shut things down. By the way its an EVO engine.
I assume my winter project is removing the inner primary and replacing the jack shaft seal. Might as well do the trany seal also since I'm in that deep.Any input will be appreciated.
Thanks
Thanks
