free website stats program 08 streetglide no ignition power after radio install | Harley Davidson Forums
pmpj172
up front thanks for any help you can suggest wracking my brain on this so here it goes.....wifey bought me a radio for my 08 street glide after installing i now have no ignition power to the whole bike turn the switch and nothing there was a blown fuse witch i replaced ,switched all relays around checked all fuses in fuse box,weird part is if i back feed 12v from the radio accessories wire system comes on?bike starts runs normal?is there any other fuses on the bike that aren't in the fuse block i should be looking at
If you did not disconnect battery when installing radio you need to check the maxi fuse....
If the '08 is same as '07, t here are more fuses under the Right side cover. It's just in front of the ECM and kind of hidden with wires.
I think the fuses in there are P&A, fuel pump and ECM.
Welcome to the forum!
