07 sportster nightster alarm problems
Discussion in 'Sportster Models' started by evorider95, Mar 28, 2011.
  1. evorider95
    evorider95 Member
    5
    Bike has not been used for 6 months. Battery is only a year old. It has been recharged. The bike wont start and the blinkers flash rapidly. All lights seem to work and electrical systems and gas pump are on. It seems that the smart alarm has something to do with this? Any help/advice is appreciated.:newsmile026:
  2. JBC2565
    JBC2565 Junior Member
    582
    Change the batteries in FOB??
  3. evorider95
    evorider95 Member
    5
    I got new batt on the fob .
  4. Hoople
    Hoople Account Removed
    7,198
    34
    Try back up FOB and place it on the seat close to the hand free module. That should override any strong RF that may be nearby. If still no start, I would manually enter the correct PIN code to confirm that it is in fact a security issue and nothing else.
  5. glider
    50
    Did the problem start after replacing the battery?
    If so maybe the battery is bad or installed wrong.
  6. evorider95
    evorider95 Member
    5
    the batt checks out ok all the gages work the gas pump turns on then the blinkers just go crazy.
  7. glider
    50
  8. evorider95
    evorider95 Member
    5
    Thanks to all for the help
    I got my bike running . I like this site.
    :bigsmiley12::newsmile071:
  9. Joyflyin
    Joyflyin Experienced Member Staff Member Moderator
    5,825
    133
    208
    That's great to hear! Glad you are back on the road. :D
  10. Jack Klarich
    And the problem was?:s
