07 Hertiage back fire
Discussion in 'Softail Models' started by amigo1980, May 8, 2013.
  1. amigo1980
    amigo1980 New Member
    4
    My 07 Hertiage Softail runs great but one day it had a backfire thru the exhaust which I had never heard before. After the backfire when I pulled up to a stop light the engine did not want to idle. Had to continue to keep the rpm's up. Started off and no problem with running and the bike did not backfire again that day. A few days later the same thing happen 1 time but clears up. Anyone know what may cause this backfire issue.
  2. Bodeen
    4,647
    73
    222
    Does the bike have a fuel module of any sort on it? What mods have been done to it? Exhaust, Air cleaner etc.?
  3. dbmg
    dbmg Guest
    If no check engine light, check the manifold for proper tightness to throttle body. Also check and be sure that both ends of battery cables both at battery, starter and ground are clean and secure. Start with the basics first.
  4. Rubyred
    Rubyred Senior Member
    1,020
    12
    Make sure exhaust gasket nuts are tight also. Sometimes they loosen up.
