05 night train engine and electrics cut out
Discussion in 'Electrical' started by steve373, Feb 20, 2011.
  1. steve373
    steve373 New Member
    i start up bike ok ride 200 yards all lights and mileometer go out and engine stops ,i turn off ignition switch ,turn back on bike starts and runs goes another 200 yards and stops again. i have recently fitted an new oddessy battery so that is not a problem anyone else had similar problem
  2. Jack Klarich
    Recheck the connections on the battery first, check the run/ kill switch and ignition switch
  3. fin_676
    5,777
    153
    284
    And on the battery cables check the ends attatched to the bike as well
  4. TQuentin1
    4,737
    142
    Is it acting like it is getting no electricity, or no fuel. If fuel (like it is running out of fuel) check this:
    Engine Dies And Runs In Spurts - Harley Davidson Community
  5. steve373
    steve373 New Member
    thanks to all problem seems to be totally electrical as instruments go out,mileometer ,warning lights and it restarts if i tun ignition off and back on again but only runs for a short while
  6. NEWHD74FAN
    8,191
    98
    19
    Looking at the age of the bike, the most used electrical item on the bike is the electro-mechanical devices...like the ignition switch. May have contaminants fouling up the contacts inside...
  7. Hoople
    Hoople Account Removed
    7,198
    34
    Does an '05 use Maxi fuses or resettable CB's. If resettable CB's, upgrade them to the proper size Maxi-Fuse.
