vinlandviking
hi guys new here and hope some one can help.the bike quit charging and i tested everything (volts ohms all connections)per the manual and stator checked out so i got a new voltage regulator and battery.now i still have the same thing. now i will get a .30 volt gain when i rev the bike if i check across the battery terms.so at the battery i get 12.20 volts running and12.50 if i rev it.so i have3 questions
1,i get 11 volts if i test the pins on the vr where the stator plugs in. i did not think the vr would let power out there, is this right?
2, could the stator be puting out the volts and not enought amps?
3,if i test the 2 wires out from the vr ,i only get 3 volts.i would think it should be more as these go to the battery is this right?
thanks for any help guys
