03 lowrider loss of all power
Discussion in 'Electrical' started by ironmanholsinger, May 16, 2016.
  1. ironmanholsinger
    ironmanholsinger New Member
    4
    hi i am new to the site and new to riding. only two of the times that i have been out riding i have had a problem with the bike losing all power first time was about a month ago was on a 2.5 hr ride stopped for about 15 mins for a break then about 15 mins after that riding home bike lost all power let sit for 20 mins rode home fine checked battry cables they were lose tighten them back up problem seemed to be gone decided to check the cables again a week later they were loose agian put lock tight on the bolts then toinight out for a 20 min ride same problem but all wires seem to be tight
  2. dbmg
    dbmg Guest
    How many keys are on your ring with ignition key???????
  3. ironmanholsinger
    4
    My ignition key that's it I keep it separate from other keys
  4. dbmg
    dbmg Guest
    OK. If you gently wiggle switch with key in can you duplicate concern?
  5. ironmanholsinger
    4
    tried that wasnt able to duplicate
  6. dbmg
    dbmg Guest
    Have you checked that all fuses are secure. And you checked all battery cable connections. When you loose power all electronics are dead?
  7. ironmanholsinger
    4
    all battery cables are tight dont know where my fuses are and i loose everything motor dies and all electronics
  8. dbmg
    dbmg Guest
    Under left side cover. Have you had battery bench tested?
  9. Jeff Klarich
    4,797
    103
    484
    Have you checked for any diagnostic codes?
  10. Jack Klarich
