I have a friend with a carbureted 2003 FLHTC. He is having an intermittent ignition problem (I believe). The bike dies like you shut off the kill switch.The failures are few and far between. All the other lights are operational when this occurs. It will restart after it sets for a very short period, sometimes immediately.It has a new module on it. I`ve heard some of these bikes have a tip-over switch, which if it does might cause a similar problem if it failed. I`ve checked for fault codes and none show up.The charging system is good. He has had the battery cable come loose and cause trouble before. I know electronics don`t like that. Has anyone ever experienced this ? Thanks in advance.
