03 fatboy eng. light comes on then off.
Discussion in 'Softail Models' started by fattyboy, Jun 8, 2012.
  1. fattyboy
    fattyboy Active Member
    105
    Hi all,I have a 03 fatboy,when i start it ,It runs for about 20 seconds then the engine light comes on then it gos off after about 10 seconds,and some times it comes on while driving down the road,gos off after awhile. the bike runs fine,all i did is change the oil and filter and the spark plugs and tires. Please help.
  2. RibEye
    RibEye Junior Member
    993
    61
    One common cause, considering your input, would be the crank position sensor. Many folks damage them when removing their oil filters, using a tool. Due to proximity, the tool can apply excessive pressure to the sensor, causing intermittent faults.
    Good luck,
    Rich P
  3. Hoople
    Hoople Account Removed
    7,198
    34
    The light is telling you that a DTC code has been logged. Pull the codes and see what ECM is trying to tell you.
  4. Jack Klarich
    http://www.hdtimeline.com/archive/t-729.html As Hoople said pull the codes write them down and post them here:s
  5. fattyboy
    105
    Thanks Jack
