02 Road King power loss above 70 mph
Discussion in 'Engine, Fuel and Exhaust' started by Photorider1961, Jun 25, 2010.
  1. Photorider1961
    Photorider1961 New Member
    3
    My 2002 Road King has been running great until recently. Whenever I get on the highway at speeds above 70 mph I lose power until I drop to around 65 then power comes back. This is getting to be 70 to 80 % of the time. There have been no changes to the bike in the last year. This is a stock bike with the exception of slip on pipes, larger breather and rejetting of the carb. Idle is fine and all speeds up to 70 run great. :small3d011: Any suggestions on where to start. Any and all help appreciated.
  2. HDDon
    5,542
    133
    229
    Have you had the top off the carb lately? If so the diaphram may be pinched. Try moving the slide up and see if it moves freely and drops back down evenly.
  3. glider
    How is tha air cleaner, does it need cleaning?
  4. twicecam
    twicecam Active Member
    241
    When was the last time you changed the fuel filter? :D
  5. FishHunter
    FishHunter Active Member
    134
    Might want to do a compression test, to see if at least, both holes are equal.:s
    Scott
  6. Photorider1961
    3
    Thanks all for the reply. Will begin today on resolving this issue. Will post outcome.
  7. NEWHD74FAN
    8,191
    98
    19
    1+ for possible obstruction in the fuel filter, fuel petcock (vacuume diaphram/line), fuel tank lines or picked up bad fuel (water or rust debris). Only then should you start looking at electrical and compression...just because it is easier to start off with less invasive troubleshooting basics first.
  8. Photorider1961
    3
    I started with the air cleaner, still doing it.. Then I pulled the carb and thouroughly cleaned it. This took care of the problem. I guess I had some crud in the carb. I pulled the jets and everything. Thanks all for the suggestions.
    Ride on
