I have a 79 shovel that is 41/2 stroke 4 in pistons forgot cam but it will not time correctly ultima ign when it is at tdc the light should just go out I have to turn plate all the way retarded (with hold down screws out )for it to work the way the instructions say motor run before rebuild same stuff in motor but new cam (same size cam) checked all key ways but pinion to flywheels every thing is lined up (also cam gear is on cam right) anybody know where the keyways on pinion shaft line up when at tdc(looking at cam side using the clock as reference) so I can tell if pinion spun in flywheel thanks much for help have tried new ign also to make sure it was working right same problem
