I appreciate your supportive comments. I totally LOVE Harley Davidson motorcycles. I bought my first one in 1962 for cheap as the guy wrecked it and REALLY wanted to get rid of it. I was 15 at the time. Once you rip off all the crappy Harley parts (this meant the carb and installing a magneto back in the day) Harleys become a fun and reasonably reliable bike. No matter how bad things in life get, a putt on my scooter can generally make me smile. It's a shame that most of the old school dealerships are now gone. These McDealerships are the scum of the earth and know zip about the Biker culture and lifestyle. Mostly what I see there these days are posers and wannabes. It's rare to see a company working so hard to drive themselves out of business. I travel a lot and I know there are some really great dealerships out there. Sadly, none are anywhere near me.
I do not have ABS. I bought my 2014 Road King because it was the last year to not have ABS. I HATE ABS..... I'll do the thinking, thanks. The 2010 FXSTC is a kind of Mickey Mouse setup. One pad guide pin. I HATE the pedal lever and tiny brake lever pad. Pretty much impossible to put on floorboards and a decent brake lever/pad... can be done but not cheaply. It's fine if you are just bar hopping but the configuration gets annoying on a several hundred mile ride.
A fluid flush is next up and I had already planned on giving the vent hole or whatever it is a good look-see. Mostly just accumulating info on what to look for before I open it up. The service manual is as clear as mud as far as this tiny port hole is concerned. Like, if I open the bleeder, drain the system and blast air into the hole will it completely blow out the entire path? I've seen metrics that have a one-way flapper system covering that hole that can get gunked up. My instinct says this is a master cylinder issue but I want to thoughtfully troubleshoot and isolate this issue and not just shotgun parts into it. A complete rear brake rebuild will undoubtably fix this and I'm sure I would learn a lot doing it. But my focus is on intelligently isolating the problem to the exact cause and cleaning/replacing *ONE* failing part. As I said in my intro, this is as much about learning as it is about fixing any particular problem.
I hear you about the dangers of brakes dragging. I don't want to warp the rotor, among other things. But the fact is, I am a very light brake user. I brake with my gears and by planning my stops way ahead. When that dealership blockhead claimed I was braking incorrectly I immediately knew I was dealing with an idiot. The fact is, in 99% of the cases, the only time I touch the rear brake is the final 5 MPH to zero complete stop and then usually hold with the front brake.
