As you can see I have the fork tube clamped in the bike with a air ratchet to remove the center screw from the bottom of the fork tube. My problem is the screw just spins and spins. Any help on how to remove this screw now?
Jack I think this is the left hand fork tube, he just has it is the right triple clamp for some reason. The left hand tube has a solid hole, no split. The screw he is trying to get out is into the center of the tube and holds the internal suspension cartrage. If he has already taken the pressure off the spring the cartrage may be turning. I'll go down to the shop and confirm with the manual.
HDDon... your right I have the left hand fork tube on the right hand side just to hold it tight. I have put the spring and cap nut back on to get some pressure on the internal components. This is a sportster and there is no cartrage. I will have to figure out away to put more pressure on it, unless someone has a way of breaking it loose....thanks you guys.
