grumpygrandpa
I have heard pro's and con's about changing my 2002 88B motor from the spring-loaded cam tensioners to the hydraulic cam tensioners with the new Screaming eagle cam plate kit and new oil pump. Now I have been told that the outer cam bearings are the same size as the OEM. And the oil pump is much better for oil flow as well, 25% better flow. and along with the cam tensioners not wearing themselves out with better pressure on the cam chains. which I think might be great to upgrade too. But I also heard that the Screaming eagle cam plate kit is junk? I guess this is Harley Davidson fix or an upgrade. does anyone know about this kit?
