free website stats program 01 Dyna Wide Glide will not crank | Harley Davidson Forums
Captamer1
I read a spread in here regarding a bike not cranking. Did the test that was suggested removed the TSM used two wires crossed them the bike crank over and started. Use the vom on the suggested pin holes I got 12 volts when I pressed the start button. Solution seemed to be replaced the turn signal module which I have didn't fix the problem. What do I do now?
Use a thick wire between the + of the batterie ,and the starter.
If it cranks then , check the starter-relay if it gets power , if not check back to the startbutton, and then back to the fuse.
good luck.
I've tested the starter and starter solenoid the engine will crank. I put in bypass wires for the turn signal module and it will start I've tested the pins for the turn signal module that control the push button starter I get 12 volts from that. So now I'm lost I don't know what else to look for
Welcome aboard from Gulf Coast AL.
Sounds like there are problems in the turn signal module, hopefully someone will chime in to help.
