XLH 1200..small electrical/charging problem.
Discussion in 'Electrical' started by TheWolfman, Oct 26, 2012.
  1. TheWolfman
    TheWolfman Member
    8
    hi..i have a 1200 sporty and im currently experiencing some electric/charging issues. it wont start without charging the battery for a few hours first or bump/jump starting it..when it doesnt start,all i get is clicking from my starter motor..i can hear it spinning,but i guess it isnt getting enough charge to push forward to turn over the eninge. once i get her running,shes fine (i even got her up to 100mph the other day so i know the performance isnt effected) and most of the time when i go to start her up,she aint having none of it. plus ive recently fitted a brand new Motobatt high torque battery with tight connections at the terminals,so i know its not that.
    i understand that its likely to be my regulator rectifier that could be the problem,as ive read online that if the diode goes in the reg rec,it can cause battery drain,which is what im getting. i also understand i could be loosing charge via a poor earth connection..can anyone give me any advice as to where my earthing connection could be?
    any help would be greatly appreciated,as ive been a harley owner since december,so im still pretty new to where everything is.
    ill try and take pics of around my regulator rectifier and post them up so you can see if my earth connection is in the shot.
    cheers,
    Wolfman
  2. fin_676
    5,788
    153
    287
    The voltage regulator is earthed through the bolts that mount it to the frame make sure that the the bolt points are clean and free from corrosion on both the regulator and the frame
  3. TheWolfman
    TheWolfman Member
    8
    as simple as that? cheers..to be honest it is abit mucky around there..ill try and get some fine sandpaper & wd40 and give it a good cleaning tomorrow (if we have a dry day)..also ive got some damp start plastic film spray,so when im done,ill give the reg rec and the bolts a good coating to protect it.
    cheers,
    Wolfman
  4. fin_676
    5,788
    153
    287
    Perhaps the end is here for the voltage regulator i have had to replace a few on older bikes over the last few years
  5. TheWolfman
    TheWolfman Member
    8
    hmmm..so you think it might be worth just getting a new one? as mine is pretty rusty at the mo lol
    Wolfman
  6. fin_676
    5,788
    153
    287
  7. TheWolfman
    TheWolfman Member
    8
    cheers mate..yes,£58 seems to be the going rate for reg recs in uk,but ive found them for around £34 from J&P cycles over in the states..but it could take a week or two,maybe three for it to be delivered. dilema or what! haha
    Wolfman
  8. fin_676
    5,788
    153
    287
    When buying from the usa sometimes the tax man catches you and applies vat to the package including the postage then the courier that is collecting the vat charges a collection fee of £10 to £15 and delays the part arrival
    However you may not be in a hurry for the part as here anyway it is time to lay the bikes up for the winter as the snow gates are closed in the southern part of the county and the ploughs and gritters are out throwing their mess around trying to keep the roads open
  9. Jack Klarich
  10. TheWolfman
    TheWolfman Member
    8
    right..i had a look at my regulator and its all corroded and crudded up,so ive decided to get one...ive unbolted it from the frame and unplugged the 2 pronged plug just underneath it and there was abit of junk on that...so now ive got to find out where the other wire goes (somewhere under my seat) so the i can totally disconect the rer rec ready for getting my new one..im abit skint at the mo,so ill have to wait a few weeks (somehow lol) to afford a new one.
    Wolfman
