?? With a 1997 FLSTC Steering head? Help
Discussion in 'Softail Models' started by CMcCoy72, Jan 3, 2016.
  1. CMcCoy72
    CMcCoy72 New Member
    4
    HeyGuys, I have been around for a while but not posted, Well I ran into something I cant figure out. I want to adjust the steering head bearings on a 1997 Heritage softail, standard fork. I have the Harley service manual, but don't see or understand how this adjustment works. For most of the other Harleys including the heritage with a springer front, it shows a adjuster nut or a typical nut with the slots in it that you have to turn on top of the steering head bolt, under the chrome cap. BUT in the manual for the flstc and in the parts diagram it does not show this. It says there is a adjuster nut , which in the diagram shows it to be under the left side bottom pinch bolt which makes no sense to me. Any one have experience with this that can help, I did remove the chrome cap and there is the top nut but no adjuster type lock nut under it, and as I say the manuals show it to be at the same place as the left bottom pinch bolt, like the pinch bolt threads through it , makes no sense to me how that could work even if it is there. Thanks
  2. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    I just looked at a parts diagram for your bike, and I have to agree with your description. Hopefully, a Heritage owner will log in soon and help.
  3. CMcCoy72
    CMcCoy72 New Member
    4
    Ya I think the parts diagram is way off, what they are pointing to and calling the adjuster , looks like the lock washer on the pinch bolt, so I am wondering if you adjust the bearings by just the top bolt on the stem, or if there is something in the bottom of the neck I cant see.
  4. HDDon
    5,562
    133
    236
    On my '94FLSTC the top nut is the adjustment to loosen or tighten the neck bearings. I sold the bike and let the manual go with it so I going from memory here.
  5. CMcCoy72
    CMcCoy72 New Member
    4
    Thanks Don that's what I am thinking also at this point.
  6. geezer
    geezer Senior Member Contributor
    1,709
    68
    73
    On my 09 Heritage, I loosen the pinch bolts and then adjust the fall away with the top nut. There is no way to lock the top nut so I'm guessing only the torque applied to the top nut keeps it tight and hopefully it doesn't loosen on it's own.
  7. CMcCoy72
    CMcCoy72 New Member
    4
    Thanks geezer , I guess mine is the same, because as you say there is no lock nut etc on the top and that's the only adjustment I can find on the steering head.
  8. Benito1976
    Benito1976 Member
    40
