Wiring Newbe, again
Discussion in 'Electrical' started by neverdown, Jul 21, 2008.
  1. neverdown
    neverdown Member
    22
    I ran a jumper wire from the positive post to the relay on top of the solenoid ( assuming this should crank the starter )..... nothing. Bads starter? Is it possible I burned something out when I tried to start it, if the wiring was not right?
    Thanks
    50
    You have to run that jumper to the small terminal with the green wire that is on the solenoid. If a no start or crank occurs, it could be the solenoid or the starter. You can jump the solenoid directly to the starter input to verify the starter itself.
