Sproder
Hi, I am wiring a bike with the help from a diagram on this fourm, I'm trying to incorperate the nutral switch and clutch switch to work togather to start the bike in gear with the clutch in, or in nutral with clutch lever out but not to turn over in gear. My problem is my clutch switch cuts contunity when pulled in, and i don't want the nutral light to go out when I pull the clutch lever in. I am using stock 09 V-Rod switch housings, as stock the clutch switch is used by the TSM to work in this way, I'm not using a TSM. Any help would be appriceated. thx
