why is my voltage regulatoe smoking
Discussion in 'Electrical' started by bushwhack, Feb 20, 2016.
  1. bushwhack
    bushwhack New Member
    I started my 98 softail after it has warmed up and the voltage regulator started smoking. Whats up
  2. Jeff Klarich
    4,806
    103
    487
    STEVE07 likes this.
  3. Jack Klarich
    Make sure if you replace the regulator it is grounded good
  4. Jack Klarich
  5. RibEye
    RibEye Junior Member
    992
    60
    Oil drippage?
    Bad stator?
    Shorted rectifier(s)?
    Excessive load?
    Bad regulator?
    Conductive bits from the primary found their way into the stator area?
    Good luck,
    Rich P
  6. SledDog
    SledDog Senior Member Staff Member Moderator
    2,120
    68
    88
    Have you changed the oil recently? If so maybe you have oil on it, or you oil filter is leaking. And that oil is burning off once the motor warms up.
  7. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Give the Primary oil a SNIF Test... BURNT smell and Color BLACK means Stator is probably toasted too...
    I Never replace on or the other...... I usually go for BOTH replaced at the same time.
    You can just replace the Bad unit tho... I found that the OTHER half of the Equation not replaced went BAD very soon for me...:eek:
    ALSO: check to see IF an abundance of Oil leaked by the Catcher when changing the oil Filter out Causing the SMOKE like mentioned above...(good Call SledDog)
    I have had the rubber electrical boot - right under the oil filter (early Dyna) Fill with oil before from careless oil filter change... and drip out onto the Regulator AND Mark my spot for parking... :mad:
  8. joel
    joel Senior Member
    1,034
    131
    All wires and electronic items have smoke in them,
    It's when the smoke is let out we have problem's
  9. coopernicus
    coopernicus Junior Member Contributor
    970
    98
    That is so very true. If they could just figure out a way to keep that smoke in we wouldn't have very many problems.
