which cam?
Discussion in 'Engine, Fuel and Exhaust' started by gottenbacher, Dec 18, 2009.
  1. gottenbacher
    gottenbacher Member
    35
    which cam SE-57 or the EV-27
  2. gottenbacher
    gottenbacher Member
    35
    1991 FLHS .010 over screaming eagle heads w/ 10.5:1 pistons
    Mikuni HSR42, Vance & Hines Pro Pipe HS 2 in 1, Dyna 2Ki-5P,
  3. B-1B_Guy
    B-1B_Guy Junior Member
    556
    I ran the EV27 in my stage 3 1997 Heritage and it was a great low to mid cam but it was tough on starters. EV46 is a good cam for EVO's as well.
  4. gottenbacher
    gottenbacher Member
    35
    Re: which cam? please give input
    Does any else have a sudjustion on these cams I was compareing specs and the SE-57 looks bigger.
  5. Breeze3at
    Breeze3at Well-Known Member
    4,923
    224
    With cams bigger is not always better, especially with a heavy bike like yours. You want low end, maybe even a EV3, the two suggested above are good cams.
  6. gottenbacher
    gottenbacher Member
    35
    I have a EV-13 in it now I just looking for more it dynos at 71/71
    Glenn
  7. Breeze3at
    4,923
    224
  8. gottenbacher
    gottenbacher Member
    35
    1991 FLHS .010 with 8:5.1 ,Mikuni HSR42, Vance & Hines Pro Pipe HS 2 in 1, Dyna 2Ki-5P, with a EV-13 Cam heads stock with new vavle and 3 angle vavle job
    I want to go to screaming eagle heads w/ 10.5:1 pistons and SE-57 cam. Just looking at other cam,piston choices to see if this make since for perfermace or cost one way or the other. I know there are other ways to make my heads do the same perfromace or better, But I like the Screaming Eagle look. Just me In September I took it to the strip and pulled mid 11: my first runs on a strip. (was a ton of fun)
    Glenn
  9. Breeze3at
    4,923
    224
    Was that 1/8 mile? That would convert to aprox. 16 sec. 1/4 mile, which would be about right for a FLH with stock heads and first timer launches and shifting. If it was 1/4 mile, all I can say is Unbelieveable!
