free website stats program Which Cam?? | Harley Davidson Forums
Which Cam??
Caper
I need some advice/suggestions on which cam will suit my needs. The bike is an 88", '03 FLHPI and I've got V&H Ovals, SE Breather,and SE Pro Race Fueler(NIB for $75.00)(Nothing installed yet)
I'm looking for passing power at hi-way speed(55-65MPH) without jamming it to redline, but don't want to loose too much down low. These are the 3 choices I'm looking at.
Crane 1-300...Duration 226/236.. Lift .505 TDC .147/.152 Int 13/33 Exh 42/14
Andrews TW26a Duration 226/230 Lift .490 TDC .138/.112 Int 11/35 Exh 41/09
Wood TW6 Duration 240/240 Lift .510 TDC .189/.178 Int 20/40 Exh 42/18
HP/TQ claims... Crane, idle -5000, Wood, idle- 5500 and Andrews,1800-5200
Would these cams fit the bill?? What is the redline on a stock ECM??
Is there another cam out there that may be a better fit??
TIA:)
Thanks Hobbit, Andrews is very popular, I'll probably install a .030 head Gasket, I guess another way to ask is, which one is in its sweet spot around 2800- 3000RPM??
May want to investigate a Wood 6-6 with a 4* advance gear.
Hits hard and carrys out. Best of both worlds.:small3d026:
FishHunter,I do like Woods cams, I think what I'm gonna do is put the Stage 1 on and run the bike a bit to see exactly where I want the cam to come on and where I'd like it to peak,then investigate which one has the characteristics I'm looking for.
HQ0034 is another one I'm gonna include as a possible.
Thanks for the suggestions fellas:)
one thing about the wood cam is when you decide to bump the ci up and some head work just takethe 4* advance out and your golden.
also got to love the Andrews always a winner
G
hi ?? for me i`m new to cams. i have a 09 ultra and i plan on cams.looking like wood 6-6
what is the reason for the 4 deg advance and what does it do for the bike
thanks
You can lower or raise the power curve on a cam using the 4*. It will also effect your cold cranking pressures too .
When I did the roller chain upgrade to my '99 Ultra I went with ANdrews 26N cams. Those cams, along with a set of V&H slip ons, a Dobeck TFI, and an Arlen Ness Big Sucker air cleaner give very good performance and the gas milage wasn't effected all that much. I am very pleased with the Andrews cams.
