wheel bearing tools
Discussion in 'Wheels' started by kemo, Jul 18, 2009.
  1. kemo
    kemo R.I.P
    1,690
    5
    When changing wheel bearings is it nesescery to use a tool or can you improvise.
    50
    Some of the older ones you could improvise but with the newer bearings, it's best to use the puller to avoid damaging the bearing especially on the ABS bikes.
  3. Bud White
    3,270
    well ya sort of need the blind puller to but you have to improvise on it the one i bought was a slide hammer and no go.
    so i made it into a puller and then got a cheap installer off ebay with the cones to press on the outer bearing race to put it in just like hd's.
    total i might have 70$ and 4 mins worth of welding to make my remover
  4. RetiredJake
    RetiredJake Junior Member
    862
    How about some pictures of what you put together
  5. PonchoDoc
    PonchoDoc Member
    21
    I'd be interested in pics too, I cant see anyway to pull the bearing from a 2006 dyna wideglide w/o a special tool.
  6. 2wheels4life
    2wheels4life Member
    20
    I simply use a long drift or punch and ALWAYS put new bearings back in, never re-use the old ones.
  7. Bud White
    3,270
    i'll try to get pics up shortly
  8. PonchoDoc
    PonchoDoc Member
    21
    Ive looked at my friends hub and didnt see any way to get a drift or punch to catch unless just start going at the side of the bearing but it being smooth didnt think that work to well. May have to give that a try though.
