Wheel bearing help please.
Discussion in 'Wheels' started by gambler2jake, Apr 4, 2013.
  1. gambler2jake
    gambler2jake Member
    I have a 91 fxstc. Took the front wheel off for the first time to and wanted to check the bearings. Well the bearings look fine my only concern is all the play in them I can pull the bearing out of the race about a 1/4 to 1/2 before it gets to the oil seal and when I do that I can wiggle and turn the bearing sideways quite a bit. I have never had it apart before so don't know if its the wrong size or the oil seal is wrong just seems like a lot of play and the book don't say a whole lot about it just don't want something to happen cruising down the road please help
  2. Jack Klarich
    Did the bearing spacer get dis lodged or is it the wrong one?
  3. Breeze3at
    Breeze3at Well-Known Member
    4,923
    224
    Those are two piece conical bearings. They need periodic repacking with grease, and close visual inspection for pitting, etc. The seal is easily pried off with a screwdriver, and needs to be replaced. See att. pichttp://www.ebay.com/itm/HARLEY-WHEEL-BEARINGS-BIG-TWIN-SPORTSTER-WHEEL-BEARING-Replaces-HD-9052-/261191492314?pt=Motorcycles_Parts_Accessories&hash=item3cd039e2da&vxp=mtr.
  4. TQuentin1
    4,737
    142
    I think Captain Jack has got you sussed. Attached is the wheel section of the 1991-1992 Softail Repair manual. I am guessing the spacer is inside the hub somewhere.
  5. gambler2jake
    gambler2jake Member
    Thank u for the diagram its in better detail then mine and got it all put back there was just a lot of play cause the spacer and shaft were removed its all good now
  6. Jack Klarich
    :D Always like a happy ending
