Whats wrong with syn 3 ?
Discussion in 'Oil' started by Big Rol, Mar 3, 2010.
  1. Big Rol
    Big Rol Active Member
    166
    I had my bike shipped to Can from Kentucky, the dealer done a complete fluid change at 15,000 which is whats on the bike. On the phone it was amsoil but the service sheet says syn 3. After reading multiple posts I'm getting ready to drain the fresh change and start over, I didn't see any specific knocks on syn 3 just a pronounced overall dislike. What is its problem and should I change it now or wait till the next one is due?
  2. Jonas
    Jonas Junior Member
    408
    Just wait until it's time to change. You have nothing to worry about. Its just discussed on the internet so much, it seems to be a bigger deal then it is.
    Note: If the bike has sat for a long time(over a year)since the change, you might want to consider changing it.
  3. Big Rol
    166
    Thanks Jonas, the bike was serviced in early Jan. so I should be good to go :)
  4. silentflyer
    silentflyer Active Member
    341
    Alot of guys (me included) have problems with it's producer Citgo, and their owner Hugo Chavez and his communist politics.
  5. HarryB737
    HarryB737 Junior Member
    656
    BIG 10-4 on That
  6. Dr. Dolittle
    6,404
    118
    29
    There's nothing "wrong" with it in the sense that it might harm your bike. It's just that there are LOTS of better alternatives!
  7. WildThang
    WildThang Member
    59
    As opposed to the good guys from the other Oil companies....LOL
  8. glider
    50
    It's a BLEND that costs as much as a real synthetic oil, not a full synthetic and I wouldn't buy anything made by Hugo Chavez.
  9. dfbales
    dfbales Active Member
    143
    just another low bid Item sold at top prices
  10. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    IF PUT INTO ALL 3 HOLES.... I WOULD DRAIN TWO OF THEM
    chain case/clutch and tranny need a BETTER GEAR LUBE
    harleys FORMAL+ is a much BETTER product for the clutch case AND tranny
    THE TRANNY needs a good gear lube NOT SYN3 to me if I used syn3 it would be a SIN!
    I USE REDLINE PRODUCTS AND HAVE FOR MANY YEARS..... ON rebuilds that i have done... I find hardly any wear for the miles i have chocked up on my rides.
    MY ENGINES use 25/50 redline...HARLEY oil filters
    Clutch Chain Case= redline MTL or their SPECIAL primary oil for v-twins
    Tranny= shockproof heavy by redline
    THE repair shops I KNOW would agree that SYN 3 in all 3 holes IS NOT GOOD and I think a ploy for HD to make more money as I am sure they PAY MORE FOR FORMAL+(their good product) than SYN 3 cost them....SO THEY PUSH IT FOR THE $$$$$...
    The engine NEEDS a good synthetic oil (FULL) so it can run COOLER and LESS wear on all the parts especially with the HOTTER RUNNING bikes of today......
    BIKES that are AIR COOL are ALSO OIL COOLED... FULL SYNTHETIC oils do a better job of REMOVING HEAT OFF THE PARTS AND COOL THE ENGINE DOWN more than a OUT OF GROUND BASE....
    harley oils like their dino oil 360 and FORMAL+ ARE GOOD and Spectro is another FINE product (not harley made) made for chaincase and tranny a BUT I'll stick with the BEST... by me REDLINE PRODUCTS....
