free website stats program What Do These Codes Mean? | Harley Davidson Forums
philipk65
Hi, I retrieved the trouble codes from my '05 FXST with an 88 engine.
Can someone tell me what each of them mean and how the fix the problem.
PO563 Battery voltage high
B1006 Acc. line over instruments
B1007 Ingnition line over instruments
Thanks! Kevin
Test the charging system should be 14.3to14.7volts @ the battery with the engine running. Sounds like yours may charging at a higher rate possible
voltage regulator. Running any sytem with too high a voltage can be damaging.
