well, that was a surprise
Discussion in 'General Harley Davidson Topic' started by macmic87, Aug 16, 2013.
  1. macmic87
    macmic87 Member
    29
    1999 fatboy and gave it the first oil change since I have owned it (5 days). new filter and 3 quarts of 20w-50. finally got the registration and was happy to go for the first official ride. after a nice 12 mile trip, pull back into the garage and shut it off. wait a few minutes and stand it up to check oil. pull the dip stick and oil comes running out (darn it!!!). must have pulled out almost a quart and a half to get a normal reading. guess next time a should get it running for awhile before I changed it next time. oil must have drained into sump. has me thinking that maybe I should drain it again and put in fresh since there must have been leftovers.
  2. Jack Klarich
    Try 2 1/2 quarts of oil next time. There will always be almost 1 qt of oil left in the crank case when you change your oil
  3. gator508
    gator508 Well-Known Member
    2,786
    186
    Jack is right on here, just changed mine, added exactly 2.5 quarts and after a short ride was halfway up on dip stick.
  4. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Where did you drain oil from when doing change? It is highly unlikely, but possible that a new owner drained the transmission, then put 3 qts. back into a tank that was very low on oil. Check your transmission oil level. I just want you to make sure you are not running an empty transmission.
  5. Bodeen
    4,647
    73
    222
  6. macmic87
    macmic87 Member
    29
    there is a hose with a plug in it. that is where I drained the engine oil from the tank. the trans drain is between the shocks, right?
  7. gator508
    2,786
    186
    Yes you are right. The oil is drained from the oil tank and trans from between the shocks.
  8. Breeze3at
    4,926
    224
    Yep, you are good.
  9. fin_676
    5,788
    153
    287
    It is best to get the engine oil nice and warm before draining it it will wash through the whole engine and pick up any deposits laying there and the oil will flow much better from the oil tank
    I have a 20 mile round trip i do prior to an oil change just watch for the hot bits when working on the bike
  10. SixPak
    SixPak Junior Member
    418
    38
    10
    Not sure about your '99, but on my 2007 FXST, the oil level has to be checked with the bike leaning over on the kickstand.
