Weekend Wrencher
Discussion in 'New Member Introduction' started by Jeff Tomlin, Jan 14, 2019.
  1. Jeff Tomlin
    Jeff Tomlin New Member
    3
    Hey Y'all,
    My name is Jeff Tomlian, I am from South Central Pa, close to Gettysburg. Although I have read and been helped by reading these types of forums, I decided to join one and see what more I can learn. I have always been fascinated by Harley's but could never really afford them or afford to fix them. I acquired an older Harley last year (2002 FLHTCUI) and put on my learning cap. I love to tinker in the shop and the bike I have has given me endless hours of satisfying tinkering.
  2. Blue Wide Glide
    Blue Wide Glide Junior Member
    627
    65
    Welcome to the Forum from NW Indiana Jeff, you'll find lots of tinkering ideas here!
  3. Jeff Tomlin
    3
    THANKS Blue Wide Glide....looking forward to it...
  4. dolt
    dolt Senior Member
    2,270
    103
    380
    Welcom, 2002 was a great year; hot forged crank, Timken left side crank bearing and Delphi EFI (if not a carb); all in all, a great platform for anyone with a bad case of "tinkeritus".;)
  5. fin_676
    5,903
    153
    316
    Welcome to the forum from Scotland
  6. liquid_wrench
    liquid_wrench Active Member
    338
    38
    37
    Jeff,
    Welcome from Ohio
  7. Jeff Klarich
    Jeff Klarich Experienced Member Contributor
    5,191
    183
    566
    Welcome to HDT from sunny AZ.
  8. Jeff Tomlin
    3
  9. Harttoo
    Harttoo Well-Known Member
    2,544
    198
    Welcome from Wisconsin.
  10. dolt
    dolt Senior Member
    2,270
    103
    380
    Don't know why I didn't see the post; I should see all "new posts" but didn't see that one. The link didn't work. You can PM me or perhaps start another post "Failed Cam Bearing".
    Further to that point, the OEM bearings are INA bearings and one of those things that most change on early models the first time they change/upgrade tensioner shoes. The replacement bearing is a full compliment bearing; Torrington B148, maybe Timken now but HD sells them as well. A nasty cam bearing failure can be very damaging and could result in a complete tear down to insure that all metal debris has been removed. Sometimes, not often, the bearing boss is damaged and the case has to be repaired. Of course, all are not that bad; just depends on what happened. I would like to see your post and pictures if you have them.
    http://www.bigboyzheadporting.com/showthread.php?t=88
