Water intrusion in gear oil?
Discussion in 'Transmission' started by rocket_man, Jul 2, 2009.
  1. rocket_man
    rocket_man New Member
    Has someone devised a solution for keeping water out of the trans oil coming in through the vent hose? I've tried using a breather filter, but it really doesn't prevent intrusion during a good storm.
    Thanks!
  2. TQuentin1
    4,737
    142
    My advice: take that silly little j-tube off and go to the auto supply store. Buy a couple of feet of tubing that will fit that nipple and route the tubing over the starter and to the right-side of the engine/tranny. Snake it down by the other vent tube hang down below the engine/tranny and cut it off about 3" below. That should do it, unless you are submerging the bike (not recommended!!).
  3. glider
    50
    TQ has the solution to that problem if you ride a lot in the rain.
