free website stats program Vrod with stator wire oil leak. Does anyone have a fix? | Harley Davidson Forums
Seems to me I read someone cleaned the area thoroughly and sealed it with a high temperature silicon.
You may find some posts on this issue in the self help section.
Jeff's solution is the common fix for this leak in Twin Cams; should work for the OP as well. Cleaning and prep is the key to a long term fix.;)
I used brake cleaner to remove all oil residue and dirt. Low pressure air to dry completely and then sealed with black high temp sealant. The key is to use a small screwdriver to pull back the seal as much as possible to clean, air dry, and then force sealant into any gaps that the screwdriver allows.
