Only one should have steady voltage to it when the key is on and the bike is not running,two of the wires should be fromthe module to the coil thet tell the front and rear cylinders to fire and on the newer bikes for sure one should be from the anti-knock sensor. Hope this helps. Try doing some google searches for harley wiring diagrams you might be able to fint the one for your bike,good luck.
