voltage regulator wiring
Discussion in 'Electrical' started by The Riddler, Oct 11, 2009.
  1. The Riddler
    The Riddler Member
    10
    I am building a new bike. I cannot remember where the third wire on the voltage regulator goes. two plug into the stator, where does the third one go?
    oops its an evo
  2. TQuentin1
    4,737
    142
    On my EVO ('91 Dyna), it goes to the breaker panel (where ever that is on your bike) and ties into the MAIN 30A breaker. Same point as the hot (red) lead from the key switch. The other wire coming out of the main is also BK, but it goes up to the kill switch on the bars.
  3. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    The 3rd should go to main breaker / pos. battery.
  4. The Riddler
    The Riddler Member
    10
    thanks guys
  5. Davidw2415
    Davidw2415 Senior Member
    1,456
    46
    So, you're building a bike and you're not posting pictures for us to see as you make progress. That's just no right.
  6. The Riddler
    The Riddler Member
    10
    I dont know if I can yet. That was my 1st post.. Anyone know about the two terminals on the starter motor. what wire goes to what terminal.
    I kinda like this sight, and yes I will post pics.
  7. TQuentin1
    4,737
    142
    The positive lead goes from the positive terminal on the battery to the post on the rear of starter. The negative lead goes from the negative terminal to one of the starter mounting bolts (front one). The small wire goes to the starter relay. On mine, it is the "87" terminal. I think that wire is tan (TN).
  8. NEWHD74FAN
    8,191
    98
    19
    Sounds like he is defusing a bomb or finishing up on his bike...! In either case watch out for the BLUE wire!:lolrolling
    Actually you should have a simple schematic of bike you are modifiying, but then again, with a handle like "the Riddler" it may require the "--caped crusader and his sidekick" to help you out without it. :newsmile04: Look in the Self Help section under electrical and look at some of Glider' tips and simplified schematics to help you out if you don't have the formal wiring diagrams. :33:
